ACS TRUCKS
ACS TRUCKS
Info re acs trucks post em up pics,interesting info how to date whatever
Joemax
Re: ACS TRUCKS
Post by Joemax »
It looks to me like an Alpine Sport ad.
Joemax
Re: ACS TRUCKS
Post by Joemax »
Had these trucks for years from when I first started collecting, most unusual as there is no signs of sand blasting and they are most definitely ACS base plates. Anybody can shed some light?
Re: ACS TRUCKS
Welcome aboard joe can’t help with your question though :D
Re: ACS TRUCKS
have you had a look underneath them joe and checked the threads in the kingpin hole as they would normally show some black overspray if they were orig black
Joemax
Re: ACS TRUCKS
Post by Joemax »
Thanks for the welcome.
No, I haven't checked the bottom of the base plates actually. Might have to now that you popped the question Nick.
Re: ACS TRUCKS
Did this non pro style of ACS base baseplate ever have a purpose made rise pad
Ie a raised that was not rectangular more figure 8 sort of shape
Re: ACS TRUCKS
ive seen vintage black rubber ones for those in the past,same shape as baseplate but only in 1/4" size
Re: ACS TRUCKS
dcgnus wrote: Mon Mar 22, 2021 7:21 pm Info re acs trucks post em up pics,interesting info how to date whatever
I’ve had lots over the years
430,500,651 were out by 1976/7
Early 430’s had a fully threaded axle for loose bearings but I have never seen any of the wider trucks like that.
Then came 580’s and 650’s 1977/8
Then ACS lites 1978
The lites where the first normal trucks with out the lock nut but this design then spread to other trucks
I’m not counting 650’s as normal trucks as they were specifically for down hill.
800’s came out 1978/9
950’s 1979/80 they were a bit late to the show with the really wide trucks
Late 1983/84 they tried to make a comeback with ACS900
Re: ACS TRUCKS
Joemax wrote: Tue Mar 08, 2022 5:55 pm Had these trucks for years from when I first started collecting, most unusual as there is no signs of sand blasting and they are most definitely ACS base plates. Anybody can shed some light?
I’d say it’s hard to be totally sure, I have these sky Slalom trucks and they are almost Identical to ACS651’s there were lots of copies about back in the day apart from these
Re: ACS TRUCKS
These are the two types of”pro” baseplates with the lock nut is the earlier one with out the lock nut is the same shape as the ACS lites baseplate but not made of magnesium, to the best of my knowledge
Re: ACS TRUCKS
[/quote]
[/quote]
ive got a pair of fully threaded 500's but loose ball bearings were well on the way out by the time they got much wider
acs (2).jpg (72.87 KiB) Viewed 344644 times
Re: ACS TRUCKS
nos acs lites,took me many yrs to find these :D
acs lites (3).jpg (126.34 KiB) Viewed 344643 times
acs lites (2).jpg (116.44 KiB) Viewed 344643 times
Re: ACS TRUCKS
You’ve got the gear punkboy 😎, are the acs lights magnesium, yes them sky trucks I’ve had a few boards where they had been on since new , a Thompson and some other English deck
Re: ACS TRUCKS
punkboy wrote: Fri Sep 08, 2023 11:32 pm nos acs lites,took me many yrs to find these :D
Stunning Trucks, just need a Fibreflex Teamrider to go with, but I’d guess you have one and it’s not a reissue 😂
