Anybody tried polishing trucks ?
I’m looking advice on what to use etc, I have dremmel style thing from the centre isle a Lidl but think I might need a bench mounted one ?
I enquired about getting it done commercially but the cost was prohibitive.
Truck Polishing
Re: Truck Polishing
ive done quite a bit over the yrs,i use 4" mops in my drill mounted in a vice,a proper bench polisher is easiest but then its more expense,you can get a kit of polishing mops with diff cutting compounds,a basic kit should manage trucks easily enough,i try not to do any at all nowadays as its a filthy job
just beware the metal can get very hot as you work the piece and also hold on tight as its easy for a part to get thrown across the floor and end up with more marks to polish out ,deffo worth wearing all the safety gear,i also used to wear a hat to try and keep the filth off me as much as poss
Re: Truck Polishing
Thanks Punkboy
Good advice , May they are nice as they are
